Merlin
68000 Retro Super Computer
A flexible, open platform to learn or develop 32-bit hardware or software using either a physical or FPGA solution.
The project uses a modular design to allow you to extend or move in different directions should you so wish.
- 100 mhz 68010 soft-CPU
- L2 Cache & DDR3
- 100 mhz custom ieee754 soft-FPU
- EVE GPU
- Dual hardware OPL3
- FAT32 filing system
- Hardware accelerated tcp/ip over ethernet
- WI-FI
- Optional MCU based USB host
- Wii Controllers
https://github.com/mattuna15/merlin
The project uses a modular design to allow you to extend or move in different directions should you so wish. At it's heart is the core of a Multicomp system from Grant Searle.
IDE:
VHDL:
https://github.com/mattuna15/zed-68k/tree/arty-gd
Hardware:
  • FPGA 68010 CPU (tg68k)
  • VGA/HDMI - Gameduino 3X Dazzler
  • Board - ARTY A7-100 or 35T
  • Sound - Twin OPL3 chips (FM) and/or Gameduino PCM
  • RTC
  • PS2 Keyboard & Mouse
  • Optional MCU based USB host
  • Wii Controllers
Storage:
  • DDR3 Ram support with L2 cache
  • FAT32 SDHC Card support with C Fat Library
  • TELNET Server with support for S-Record upload via Monitor rom
  • 2x 256k SPI FRAM-NVRAM for firmware/permanent storage
M68000UM_AD_M68000_Microprocessor_Users_Manual_Rev8_1993.pdf
Adobe Portable Document Format - 10.64 MB - 02/15/2022 at 21:53
Preview
4718_MB85RS2MTA.pdf
FRAM Datasheet
Adobe Portable Document Format - 1.64 MB - 12/11/2021 at 11:17
Preview
MC68000_Educational_Computer_Board_(MEX68KECB)_[MOTOROLA_1982_227p].pdf
Tutor monitor manual
Adobe Portable Document Format - 29.04 MB - 11/05/2021 at 21:00
Preview
mcprtcdatasheet.pdf
RTC Data sheet
Adobe Portable Document Format - 980.03 kB - 07/07/2021 at 16:15
Preview
arty_rm.pdf
Arty reference manual
Adobe Portable Document Format - 1.19 MB - 07/05/2021 at 09:28
Preview
View all 10 files
View all 7 components
  • Wii Controllers Demo
    Matthew Pearce04/25/2022 at 13:02 0 comments
    2 Wii controllers are supported by the Gameduino board. They are stored in the Inputs response from the dazzler. The following information is available from 2 controllers:
    https://cdn.hackaday.io/files/1805367724052224/gameduino-3x-dazzler.pdf
    The controller can be seen working here:
  • USB Host #5 - Buttons
    Matthew Pearce04/22/2022 at 20:49 0 comments
    Here's a demo of the final code for the USB Keyboard and Mouse with a GUI button shown working for the first time. Code will be added to github soon.
  • USB Host #4 - Mouse control (with a bit of Amiga)
    Matthew Pearce04/20/2022 at 19:27 0 comments
    First stab at USB mouse control. Using the USB host shield and 328p to translate HID to PS2. There is a bit of a lag, but it seems to work. Will need to debug the MCU code I think to see what is causing the delay.
  • USB Host #3
    Matthew Pearce03/21/2022 at 12:31 0 comments
    USB Keyboard & Hub connected and now working. I created a quick sketch to convert HID codes from the keyboard to PS2 scan codes so it will just continue to work with the main hardware design with no modifications.
  • USB Host #2
    Matthew Pearce03/16/2022 at 13:52 0 comments
    I have my cheapo mini usb host shield (max3421e) connected up to a 3.3v 328p feather board. the arduino code translates the USB HID data to ps2 data for the fpga system - giving usb mouse and keyboard via a powered hub. I think I may have space for usb midi translation as well. I've been umming and aaahing about which MCU but the adafruit feather 328p seems best as it is 3.3v by default, supports all existing arduino libraries and has a lipo battery charger and pin which I can also use for battery backup to the sram controller (ds1314).
    https://www.adafruit.com/product/3458
    https://chome.nerpa.tech/arduino_usb_host_shield_projects/
  • USB Host
    Matthew Pearce03/10/2022 at 17:24 0 comments
    Purchased a cheap USB Host shield which uses a MAX3421e SPI USB controller. I'm currently finishing off the circuit design for the next version of the expansion card and I may put one of those on it. I need to port the USB Host library first to use my proven SPI code. I don't think it will be too complicated. At the moment I checked that the shield works by retrieving the Firmware version number using plain SPI. I'll pick this up again later.
    https://github.com/mattuna15/USB_Host_Shield_2.0
    https://www.maximintegrated.com/en/products/interface/controllers-expanders/MAX3421E.html
  • Expansion Board #1
    Matthew Pearce02/21/2022 at 15:14 0 comments
    Received the first prototype PCB to expand the Arty. I've created a board which has 4 pmod connectors for 8 bit data, plus another connector which uses some more GPIO pins to handle upper 8bits plus other signals such as chip selects and the like.
    It needed a bit of bodge wiring to the read/write signals due to a typo on my behalf (doh). 8 bit data works perfectly to 1 3.3v sram chip. The upper 8bits seem to be working ok with a decent cable length.
    I've also added a DS1314 soic chip to provide a battery backup and warning led to maintain memory at shutdown. The board also breaks out the full bus to a 64pin expansion connector. I'll be using that to test various level shifters and other options.
  • Asteroids #4 - Ship control, lasers and collisions
    Matthew Pearce02/15/2022 at 15:35 0 comments
    So we have a ship rotation using keyboard controls. I just rotated the vectors in excel and added them to an array, the same with the thruster vectors which are drawn twice with additive blending to increase brightness. The bullet is a simple point in the direction of the ship nose. Collision detection is just using 2 circular boundaries.
    The vectors are rotated using:
    𝑥2=cos𝛽𝑥1−sin𝛽𝑦1
    𝑦2=sin𝛽𝑥1+cos𝛽𝑦1
    where 𝛽 is the rotation angle in radians.
    collision detection is :
    asteroidX-shipX < shipBoundaryRadius + asteroidBoundaryRadius &&
    asteroidY-shipY < shipBoundaryRadius + asteroidBoundaryRadius
    This is translated into asm:
    * asteroid collisions
    ast_collision:
            *a4x a5y - asteroid
            movem.l d0-d7/a0-a6,-(sp)        ; backup registers
            lea ship_x,a0
            lea ship_y,a1
            move.l #0,d0
            move.l #0,d1
            move.l #0,d2
            move.w (a0),d0
            move.w (a1),d1
            move.w (a4),d2
            move.w (a5),d3
            move.l #20,d4
            add #8,d4
            sub.w d0,d2
            sub.w d1,d3
            cmp.w #0,d2
            bge chky
            muls.w #-1,d2
    chky:
            cmp.w #0,d3
            bge chkcoll
            muls.w #-1,d3
    chkcoll:
            cmp.w d2,d4
            blt endcoll
            cmp.w d3,d4
            blt endcoll
            sub.b #1,ship_lives   * 1 life down
            cmp #0,ship_lives * end!
            beq end
            movem.l (sp)+,d0-d7/a0-a6         ; restore registers
            bra restart
    endcoll:
            rts
    Next on the list is collisions between the laser and asteroids.
    As usual code is here:
    https://github.com/mattuna15/merlin-software/blob/master/asteroids/asteroids.s
  • Asteroids #3 - Movement
    Matthew Pearce02/11/2022 at 14:08 0 comments
    So, having created the shapes for the asteroids, ufo and player ship. It's time to move them about. The number of asteroids will be governed by the level - I've set to 5 at the moment. The starting position (x,y), heading in furmans and speed for the asteroids are set randomly.
    At the moment the ship and ufo are moving perpendicular to each other. A polar conversion routine using sin/cos is used to translate the velocity and heading into cartesian coordinates. The GD library provides lookup functions for this purpose.
    Code will be available here:
  • DDR3 Setup
    Matthew Pearce02/10/2022 at 09:24 0 comments
    This is the worst part. DDR3 - it took me ages to get it right. So I'll put some notes here to help people.
    The Arty DDR requires 2 clocks, a system clock and a reference clock:
      .sys_clk_i(clock166), //166 mhz
      .clk_ref_i(clock200), //200 mhz
     One is 166 and the other is 200mhz.
    The next is the DDR reset & enable. It is very picky.
    reset_proc : process
    begin
        sys_resetn <= resetn and mem_ready and clk_locked;
        rstn_flag <= '0', '1' after 220us; -- 200 & 750
        cke_flag <= '0', '1' after 750us;
        ddr3_reset_n <= '0' when rstn_flag = '0' else ddr_rstn;
        ddr3_cke <= "0" when cke_flag = '0' else ddr_cke;
        wait for 3us;
    end process;
     At power up the DDR must be held in reset for at least 200 micro seconds. Also the DDR enable flag must be held low for at least 750 micro seconds.
    Next is the MIG IP set up. There are lots of fiddly settings here. The clocks must be set as per the images attached to this post. In the Merlin project there is a memory block design which shows all of the correct settings. The input clock period must be 166mhz. This will give you a UI clock of 83mhz, which is the fastest speed the arty ddr will run at. I get round this by using a system cache IP running at the CPU speed at 100mhz and then letting the axi interconnects deal with it from there.
    Good Luck!
View all 54 project logs
  • 1
    Arty a7-100t full release.
    Load the .bit file onto your Arty using Vivado.
    When the monitor starts, press L, then load the firmware s-record via your favourite terminal
    https://github.com/mattuna15/zed-68k/releases/tag/ARTY-100T-v1.0
  • 2
    Fire it up
    The Program Counter will be set to 0x000400 by default so just press J and Basic will load.
View all instructions
