On the command prompt of you Raspberry Pi board type ifconfig to know the IP address of this device
From your computer's terminal, you can connect to the Raspberry Pi board
Sign in through the Sam CLI Tool
A project log for GUILLENGAP Cobot
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System & 2) Sorting Objects System
