The battery life was under 1 hour. Step 1 was eliminating the battery.
The inside was just a 200mAh battery & bog simple board, Sadly, the 5 minute timer was burned in the chip with no RC circuit anywhere. An outboard microcontroller could drop kick it every 5 minutes. It frequently stutters when water drops build up around the transducer & cover it, so a 5 minute drop kick wouldn't be noticeable.
The transformer makes 120V p-p on 1 pin if the input voltage is 5V. The other pin is connected to B+. The output voltage drops to 110V p-p if the input voltage is 4.2V. The lion kingdom wanted to reduce the chance of burning out when it runs out of water so tried to drop the input voltage with a diode.
USB power could use a bit of capacitance to keep it from browning out. The next problem is expanding the reservoir. The easiest solution is seen as drilling out the top & fitting 2 pipes. 1 pipe allows water to be pumped in from a water bottle. A 2nd pipe lets air escape. The tank needs a water level sensor. It's expensive & hard to pump water. The 1st task is finding out how long the transducer lasts.
