It became clear that air has to pass under the transducers to keep the mist from getting blown down & to make room for a fan.
The transducers ooze a little when they're turned off, but not enough to require a tub. Most of the overflow comes out of the cap when the water level sensor fails or the gatorade bottle is too high. Because of the airflow situation, a pole stand which catches the overflow just from the cap & directs it down to a tub would be ideal.
The ideal angle & height of the transducers has evolved to a fixed position which simplifies matters. The overflow always goes out the back. There could be a flat funnel with a channel to direct the overflow down the back.
![](https://cdn.hackaday.io/images/1959981627626914122.jpg)
10 meters of filament later, the stand emerged.
![](https://cdn.hackaday.io/images/7584961627626951046.jpg)
The mist still went down, but more of it is evaporating. At least it directed all the overflow into the tub.
![](https://cdn.hackaday.io/images/2917151627627071728.jpg)
It should sit farther back so the transducer dripping gets captured. There's no easy way to farsten the stand to the tub. The base needs a vertical bit which can farsten horizontally.
