![](https://cdn.hackaday.io/images/8902721662844839606.jpg)
A subtle detail was the failure of transducer #3.
![](https://cdn.hackaday.io/images/9466651662844840131.jpg)
A new one went in but still yielded a short period of low flow, then shut down & leaked lots of water. There might be a bad screw hole leaking water.
![](https://cdn.hackaday.io/images/551301662844967508.jpg)
The original transducers have lots of scale but flow like they were new. Transducer #3 got a new driver board which didn't make any difference. The leading theories are a bad cable or the transducers having to be matched to the driver boards.
![](https://cdn.hackaday.io/images/6779731662845292000.png)
A new enclosure was already conceived to move the transducers closer together. To do this, they got a common cap which would have required removing 6 farsteners to access 1 transducer. Obviously, it's not practical in a world where transducers are consumable & must be replaced 1 at a time. The mane desires would now be thicker walls to try to reduce the water leaks, possibly more transducer spacing to keep water from landing back on the other transducers, possibly a 4th transducer.
