The calibration wizard will be implemented similar to the waveform view, in a separate window.
It will guide through the calibration process, by calculating recommended settings, which can be accepted or ignored. The following calibrations have to be done:
- Voltage
- RMS with a calibration factor
- Current
- Raw Values in terms of
- Coarse Gain
- Offset
- Fine trim
I will try to present the first results until the end of the next week.
