This is just a simple example of a solenoid to use as a reference in order to get an Idea of how to improve the design. For This I just used .16 mm magnet wire, a finishing nail made of high carbon steel (probably), plastic straw, and some tape. At this stage, I can already tell that I can probably improve by using a different number of turns, smaller gauge wire, and a different material for the core. First I will take measurements, and do some calculations in the next log.
![](https://cdn.hackaday.io/images/2354751625807248453.jpg)
![](https://cdn.hackaday.io/images/7472091625807285677.jpg)
