I spent a couple of hours trying to find a way to curve wood, as I had some thin sheets I found the easiest way was to cut the sheet into narrow strips and glue them together in a curve. Unfortunately the only thing that was large enough to curve around was an old bike mudguard! To had I had a jigsaw and a router with a table. It seemed very possible
