Follow the discussion here:
https://endless-sphere.com/forums/viewtopic.php?f=30&t=11134
3D printed toroidally wound axial flux permanent magnet air core motor.
3DTAFPM?
Since this motor uses permanent magnets, you could use it for generation instead. However, this project is focused on it as a motor and wouldn't be optimized for power generation. That being said, if you wanted to do regenerative breaking for example, this is a bldc motor in an axial format.
does it work as a generator ? efficiency ? (power is around 300W from what i saw ?)
what is the price to build one ?
how hard would it be to make one that reuse magnet from old Hard drive ?
