It only took most of the summer and the fall...working a few hours here and there...but I finally have a working assembly path from Ember assembly files to a compiled elf file using LLVM-MC and LLD. Albeit with just a few instructions so far, like branches, load immediate, and a few ALU ops, basically enough to test the code and some encoding patterns. It's relatively straightforward to add more of the same instruction types to the TableGen scripts, so I can add more later as needed for simple test code. The most difficult part was handling the Fixups in the assembler and the equivalent Relocations in the linker. Such a pain! I will write up the details of that at some point in my Ember Blog.
The next step is to implement ELF loading in the Ember CPU Emulator, then and integrate DWARF with the Debugger. My original Ember Assembler was fairly limited, and a complete hack. It was something I just threw together last year to get things up and working quickly and to allow me to test emulation and encoding. The project was quickly outgrowing its capabilities, which is why I started looking for a "real" assembler to integrate with. I ended up going with LLVM, maybe not the best choice for my first try, but I eventually got it working. The primary reason for going with LLVM is that I want to ultimately support high-level languages, especially Rust, which runs on llvm, along with other languages like Swift and C.
Assembling Ember ASM
To assemble asm files into native encoded Ember binary, I use llvm-mc, which is part of the llvm compilation chain, the part that normally converts llvm bytecode (generated from a high-level language like C or RUST) into native machine code. What you effectively do is convert your native instruction pneumonics into llvm bytecode instruction by instruction, then turn them into encoded native OpCodes.
The following is an example disassembly output of the llvm-mc encoding of some asm code (Don't mind the actual instructions, since they clearly wouldn't run, they are just testing encoding). On the left are the instructions, on the right is the encoding, along with descriptions of the Fixups that are noted (the LDI instructions need addresses for the labels that will come from the Linker, and since the LDI instructions encode to two Opcodes [LDI+LDIH], the BRA instructions need updated target offsets after the file has been parsed).
.set ZERO, 0
.set MAX_UINT32, 4294967295
.set MAX_UINT16, 65535
.set MAX_INT16, 32767
.set MIN_INT16, 32768 ; Line comment
.set ScanDelay, 4
.globl _start
_start:
bra _start ; encoding: [A,A,0b01AAAAAA,0x10]
; fixup A - offset: 0, value: _start, kind: fixup_ember_branch
brl.ne testStuff ; encoding: [A,A,0b01AAAAAA,0x15]
; fixup A - offset: 0, value: testStuff, kind: fixup_ember_branch
systemInit:
ldih r0, $ffff ; encoding: [0xff,0xff,0x04,0x64]
ldi r0, $1234 ; encoding: [0x34,0x12,0x00,0x64]
ldi r1, $ffffffff ; encoding: [0xff,0xff,0x08,0x64]
ldih r1, $ffffffff ; encoding: [0xff,0xff,0x0c,0x64]
ldi r1, $7fff ; encoding: [0xff,0x7f,0x08,0x64]
ldi r3, $0 ; encoding: [0x00,0x00,0x18,0x64]
ldih r3, $4d2 ; encoding: [0xd2,0x04,0x1c,0x64]
ldi r4, systemInit ; encoding: [A,A,0x20,0x64]
; fixup A - offset: 0, value: systemInit, kind: fixup_ember_ldi_label_addr_lo
ldih r4, systemInit ; encoding: [A,A,0x24,0x64]
; fixup A - offset: 0, value: systemInit, kind: fixup_ember_ldi_label_addr_hi
ldi r4, _start ; encoding: [A,A,0x20,0x64]
; fixup A - offset: 0, value: _start, kind: fixup_ember_ldi_label_addr_lo
ldih r4, _start ; encoding: [A,A,0x24,0x64]
; fixup A - offset: 0, value: _start, kind: fixup_ember_ldi_label_addr_hi
ldis r5, $ffffffff ; encoding: [0xff,0xff,0x29,0x64]
ldis r5, $ffff ; encoding: [0xff,0xff,0x29,0x64]
brl.eq systemInit ; encoding: [A,A,0b11AAAAAA,0x14]
; fixup A - offset: 0, value: systemInit, kind: fixup_ember_branch
testStuff:
brl r12 ; encoding: [0x00,0x30,0x00,0x14]
bra testStuff ; encoding: [A,A,0b01AAAAAA,0x10]
someData:
.byte 0
.byte 0
.byte 255
.byte 255
.byte 18
.byte 52
.byte 86
.byte 120
.byte 0
.byte 17
.byte 34
.byte 51
.byte 120
.byte 86
.byte 52
.byte 18
.byte 0
.byte 0
.byte 0
.byte 0
In the resulting elf object file, the .text segment contains the following, with Relocation tags for the LDI instructions. llvm-objdump doesn't know about Ember assembly, but doesn't need to in order to read the Reloc info.
Disassembly of section .text:
00000000 <_start>:
0: 00 00 40 10 <unknown>
4: 0f 00 40 15 <unknown>
00000008 <systemInit>:
8: ff ff 04 64 <unknown>
c: 34 12 00 64 <unknown>
10: ff ff 08 64 <unknown>
14: ff ff 0c 64 <unknown>
18: ff 7f 08 64 <unknown>
1c: 00 00 18 64 <unknown>
20: d2 04 1c 64 <unknown>
24: 00 00 20 64 <unknown>
00000024: R_EMBER_LDI_LABEL_ADDR_LO systemInit
28: 00 00 24 64 <unknown>
00000028: R_EMBER_LDI_LABEL_ADDR_HI systemInit
2c: 00 00 20 64 <unknown>
0000002c: R_EMBER_LDI_LABEL_ADDR_LO _start
30: 00 00 24 64 <unknown>
00000030: R_EMBER_LDI_LABEL_ADDR_HI _start
34: ff ff 29 64 <unknown>
38: ff ff 29 64 <unknown>
3c: f3 ff ff 14 <unknown>
00000040 <testStuff>:
40: 00 30 00 14 <unknown>
44: ff ff ff 10 <unknown>
00000048 <someData>:
48: 00 00 ff ff <unknown>
4c: 12 34 56 78 <unknown>
50: 00 11 22 33 <unknown>
54: 78 56 34 12 <unknown>
58: 00 00 00 00 <unknown>
The linker will read the Reloc info and insert the proper values based on the start address of the code entry point plus the label offset. Here the code should start executing at 0x1000, or address 4096, in the final .elf file. Notice the Relocs are resolved and it's just the binary code that would be loaded into the emulator. You can see the address is now set in the first two bytes of each instruction at addresses 0x1024 to 0x1030, where above they were 0s. That's 0x00001000 for the label "_start", and 0x00000008 for "systemInit", packed 2 bytes per instruction word.
00001000 <_start>:
1000: 00 00 40 10 <unknown>
1004: 0f 00 40 15 <unknown>
00001008 <systemInit>:
1008: ff ff 04 64 <unknown>
100c: 34 12 00 64 <unknown>
1010: ff ff 08 64 <unknown>
1014: ff ff 0c 64 <unknown>
1018: ff 7f 08 64 <unknown>
101c: 00 00 18 64 <unknown>
1020: d2 04 1c 64 <unknown>
1024: 08 10 20 64 <unknown>
1028: 00 00 24 64 <unknown>
102c: 00 10 20 64 <unknown>
1030: 00 00 24 64 <unknown>
1034: ff ff 29 64 <unknown>
1038: ff ff 29 64 <unknown>
103c: f3 ff ff 14 <unknown>
00001040 <testStuff>:
1040: 00 30 00 14 <unknown>
1044: ff ff ff 10 <unknown>
00001048 <someData>:
1048: 00 00 ff ff <unknown>
104c: 12 34 56 78 <unknown>
1050: 00 11 22 33 <unknown>
1054: 78 56 34 12 <unknown>
1058: 00 00 00 00 <unknown>Just a super quick, high-level update. You can follow along from the beginning on my Blog over on Medium.
Tom
