Configuration is complete (minus any bugs I may find).
User enters a project name and category, and their first name.
The original plan was to use the user's name as part of the slideshow, and the project name as key substitutions in some of the lesson panels. This would personalize the lessons, and give the reader the impression that the program speaks to them.
It was a good idea, but I'm not now convinced this has any value. I left it in the configuration session for now. It's easy enough to remove software (or just if'def it out).
Planning on a long composition day tomorrow, I'll think it through and see if it still makes sense.
So for code, I have only some minor slideshow word processing to add, any extra standout algorithms, and I'm done. Minus debugging.
For lesson plans, I have 1 complete, 1 in the process, and 1 in planning. With 5-ish panels each and the odd single panel, I think that should be all the project needs.
An extra beta tester or two would be convenient.
Apropos of nothing, I *may* have discovered the underlying mechanism for depression. It fits with everything I know about the condition, and leads to some testable theories on how to reverse it.
Might make for a follow-on project to this one. I'll see how popular this one is before I make that decision.
