I added a couple of checkboxes to the Configuration window.
One took the place of a text field for saying "yes" to automatic PDF generation, and the other lets ShoppingList create your list title from the filename of the database you have open.
So, you can have an automatically generated title at the top of the list, or you can specify what you want to show up there. Your choices are saved to the .ini file.
Gregory Sanders
