Hackaday.io Hackaday.io
Sign up Log in
pooterbooter
Mount and boot iso images over network - pxe iPXE DI LTSP
gintaras-valatkaGintaras Valatka
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
  • 2021 Hackaday Prize
View Gallery
258
0
1
0
Team (1)
  • gintaras-valatkaGintaras Valatka
Join this project's team
  • pooterbooter
Software
ongoing project
PXE 2021hackadayprize ipxe ltsp di remote boot
This project is submitted for
  • Challenge 2: Refresh Work-From-Home Life
This project was created on 07/13/2021 and last updated 5 years ago.
Description
If you don't feel like dd'ing iso images into usb keys, then maybe read on..
Download iso images and start the admin panel. The script will find *.iso files and will let you mount it. It will also update boot menu
Project Logs
Collapse
  • v0.0.2 iPXE apt-cacher-ng di-netboot-assistant
    Gintaras Valatka • 07/23/2021 at 21:46 • 0 comments
    If you have more than one Raspberry Pi or Debian/Ubuntu, install auto-apt-proxy on every machine, which auto finds and connects to installed apt-cacher-ng server. If you reinstall or download packages on multiple hosts this will save you bandwidth and speed up installations.
    GUI to download Debian/Ubuntu - this must be the easiest way to install! No need to download full or minimal netinst iso images, no need to run md5/sha sum checks. Only the first install is slower, following installs will be lightning if using apt-cacher-ng
    Define locale/packages in admin/config.php autoinstall with preseed.cnf soon
    Can Live boot Debian and Ubuntu via NFS, can boot windows 10 setup
    /etc/di-netboot-assistant/di-sources.list could be updated with more architectures like http://deb.debian.org/debian/dists/testing/main/
    What would happen if Raspberry Pi4 was pxe booted? (I don't have one yet) http://deb.debian.org/debian/dists/testing/main/installer-armhf/current/images/device-tree/
  • v0.0.1 pxe only
    Gintaras Valatka • 07/13/2021 at 23:14 • 0 comments
    v0.0.1 is pxe only
    https://github.com/soholt/pooterbooter/releases/tag/v0.0.1
    Archlinux boots in 4min from Raspberry Pi1, ubuntu slow to dowload via 100Mb network
    It boots archlinux, clonezilla (and debian/ubuntu live (slow, (4Gb+ ram)) instructions: https://github.com/soholt/pooterbooter/blob/v0.0.1/README.md
    wait for v0.02)
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Step-by-step instructions on running Remote Desktop on Raspberry Pi with tips and tricks
Project Owner Contributor
3 Ways to Run a Remote Desktop on Raspberry Pi
dmitryDmitry
Set up a sustainable backup on Raspbian to save your files from occasional loss
Raspberry Pi Backup guide 2017
dmitryDmitry
Raspberry Pi based smart lock for apartment dwellers
Smart Lock with Web Interface
chrisChris
How to turn your Raspberry Pi into an all-in-one retro gaming console
Retropie: Full guide for Raspberry Pi
dmitryDmitry
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "pooterbooter", please tell us the reason.
Send message
Remove Member
