Disassembly of the Lamp Head
A project log for LoRaLamp AIRQuality
A Desklamp for your "Work from Home" Desk with Air Quality Sensor, LoRa, WiFi, MQTT that reminds you to open your windows for Fresh Air
ulrichUlrich 07/15/2021 at 19:440 Comments
as I wrote in the log before: I deciced to rebuilt the Head of the lamp.
The original Head of the lamp looks like this.
It is quite easy to dissasemble with the two screws.
Once removed you can Disassemble the original PCB with a screwdriver and a soldering iron:
