First Ping on the LORA TheThingsnetwork
A project log for LoRaLamp AIRQuality
A Desklamp for your "Work from Home" Desk with Air Quality Sensor, LoRa, WiFi, MQTT that reminds you to open your windows for Fresh Air
ulrichUlrich • 07/18/2021 at 20:26•0 Comments
I just sent out the first PING over the LORA WAN CHIP RFM95 to a local TheThingsNetwork Gateway that is more than 2km away!
This is a transmission on 868MHz. Impressive that this even works with the PCB Antenna that is covered insde the metal Lamp Head :-)
More Messages:
