We wanted the deathboard to have a few different pattern options that we could cycle through with a button.
We defined the button pins
Added an interrupt, set brightness to 50% and added a blink to the button LED to indicate when the code is finished uploading.
We added a switch case with 3 different light patterns and a 4th one that would turn all the lights off.
Alpenglow Industries
