14 bit BCD to 4 x 7 segment display
This little unit was designed to convert a 14 bit BCD signal, to display the result on four 7 segment diplays.
0 followers
The unit will display in decimal, the BCD input applied to the address inputs. The BCD code is converted and multiplexed using an EPROM.
EPROM CODE.zip
EPROM CODE (in S2F format)
x-zip-compressed - 62.56 kB - 07/14/2021 at 23:54
Download
BCD MUX PCB.pdf
PCB
Adobe Portable Document Format - 44.94 kB - 07/14/2021 at 23:54
Preview
BCD MUX SCH.pdf
Schematic
Adobe Portable Document Format - 12.34 kB - 07/14/2021 at 23:53
Preview
14 Bit BCD to 4 digit 7 segment LED driver.pdf
Full description
Adobe Portable Document Format - 23.56 kB - 07/14/2021 at 23:53
Preview
