7/29/21
Following Ed's instructions, I created a micros.js file that is referenced to from index. This js file is used in conjunction with arduino_compressed.js and blocks_compressed.js. Basically, everything needed for micros() to function is in the micros.js file.
A couple questions did come up while putting the code together(and I emphasize "putting it together" because there wasn't much I did except analyze the code for what's necessary), 1) Why can't I seem to consolidate the two over-arching UMDs?(New term I learned while googling! the function(root, factory)). If anybody can shed some light on that, that'd be awesome.
Also, should I change the block's location, what other changes would I need to make to code?
Heading to Norcal soon! Have a great weekend everyone :)
richard
nice!
UPDATE: Created own Time category w/ new color for block as well.
