For this entry, I will be updating my progress on the print image block.
I have defined the block to take in 5 parameters: a string (hex string), and four ints (each for X and Y coordinates as well as width and height).
Here is the generator bit:
For some reason, my program did not work, so I asked Dante if he could try running these changes on his computer (which worked).
Anyways, with the hex string that is obtained from the website Richard was working on, this block would take the string and the four numbers, then the generator that Dante created will convert the hex string to get the array that will be used to display the image on the screen.
Nice, Sion. Can't wait to use the block!
