Digital simulation is quite straightforward. GHDL is well established here. I implemented a simple counter in VHDL to use an example for flow development. The source code is shown in the figure below and simulation traces from the testbench at the bottom of the page.
I implemented this part of the flow based on a standard Makefile. I switched to normal bash scripts for later parts because it became difficult to track built dependencies across folders. I may have to look into Tcl/Tk or other solutions at some point.
entity counterx is
port (clk: in std_logic;
rst: in std_logic;
count: out std_logic_vector(2 downto 0)
end;
architecture main of counterx is
signal cnt: unsigned(2 downto 0);
begin
process (clk,rst)
begin
if rising_edge(clk) then
if (rst = '1') then
cnt <= (others => '0');
else
cnt <= cnt + 1;
end if;
end if;
end process;
count <= std_logic_vector(cnt);
end;
Tim
