Hackaday.io Hackaday.io
Sign up Log in
ATtiny814 USB RTC
Real-Time Clock USB-Stick based on ATtiny814
stefan-wagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
807
0
4
3
Team (1)
  • stefan-wagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
hardware
ongoing project
attiny814 attiny tinyavr avr arduino RTC clock pcb UPDI usb attiny214 attiny414 attiny1614
This project was created on 07/18/2021 and last updated 2 years ago.
Description
The USB-RTC is a simple real-time clock that can supply devices without one (e.g. Raspberry Pi) with the current time and date via USB. The CR1220 or CR1225 backup battery keeps the clock running even without an external power supply. The built-in 32.768 kHz crystal ensures a reasonable accuracy of the clock. The on board CH330N (or CH340N) USB-to-serial adapter can also be used as a UPDI programmer, so that no external programming device is required. This makes the USB-RTC also suitable as a development board for RTC applications based on the new tinyAVR or megaAVR microcontrollers.
Details
Log In/Sign up to comment
Sign up with Github
OR
Learn how to create One Time Pads and USB dead drops.
Project Owner Contributor
The NSA, Snowden, And Citizen Cryptology
steve-schulerSteve Schuler
A 4 port RS232 Adapter
USB to 4 RS232 Ports
bharbourBharbour
This tutorial will show you how to hack your audio devices using Airplay to stream music remotely with Omega.
Hacking Stereo with Onion Omega
onionioOnion.io
MCP2221 USB-I2C Converter | DS3231 High-Precision RTC Chip | TCXO | Inbuilt-Temperature Sensor | Cross-Platform Compatibility
USB Real Time Clock Dongle for Raspberry Pi - RTC
undefined
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "ATtiny814 USB RTC", please tell us the reason.
Send message
Remove Member
