MAST Cell for Wildlife Research
(M)iniature (A)rgos (S)atellite (T)racking Cell for Wildlife Research
This open source wildlife tag uses the Argos system currently aboard 7 satellites to track any non-marine animal on Earth. This tag is specifically designed for use on small birds, but can be used on any terrestrial wildlife as well.
Current commercial solutions for bird tracking are bulky, heavy, and expensive. Certain trackers on the market can cost up to $3000 per tag. With this project, we aim to provide a cheaper and lighter solution for researchers around the globe.
CNES plans to have up to 25 nanosatellites with the Argos system onboard in orbit by 2023. These new satellites will give 15 minute location updates with accuracies up to 150m.
All project files are open source on Github. (https://github.com/DanielHeEGG/MAST)
Warning: This transceiver is being developed and HAS NOT received certification yet from CNES.
Goals
- Less than 10g in total weight
- Up to 1 year lifetime
Target Use Case
Bird tag in image is not the tag in this project. This is simply a usage demonstration.
  • v0.1 - Rev. 1
    Daniel He08/21/2021 at 16:25 0 comments
    Commit 7d753bf
    Minor component & silkscreen changes.
    What worked:
    - SPI flash
    What didn't work:
    - Solar charging
    - 1.8V buck converter
    SPI flash orientation was fixed and the chip was immediately detected by my programmer. No problems there.
    Adding a 43K resistor (top left, 0603, not soldered in image) to the MPPC pin didn't seem to do much. I'm probably going to figure out the solar charger in a separate PCB so I don't have to order 6-layer boards every time.
    It turns out that I also had the wrong footprint for the 1.8V buck converter IC (top center, 8-ball BGA, TPS62748). The IC is 0.4mm pitch, and the footprint in the KiCAD default library was 0.5mm, I didn't notice.
    For some reason, the same chip in the last batch was placed so perfectly in the center that it didn't raise a problem on both boards (I have 2 boards assembled each revision).
    This time, none of them worked.
    One was drawing >500mA idle and heating up like crazy, the other one just had nothing on the 1.8V rail.
    Hotspot on the top is the 3.3V LDO, the one on the bottom is the 1.8V buck. (alignment’s pretty bad)
    No big deal though, I just removed the 1.8V buck converter and soldered a wire to it. I'll feed 1.8V manually while testing.
    More updates on the RF section coming soon.
    Also, if anyone has any idea of how to make the solar charger IC (LTC3105) work properly, please leave a comment.
  • v0.1
    Daniel He07/21/2021 at 11:01 3 comments
    Commit 13a81ae
    First prototype. Based on the reference design provided by Arribada. RF traces are calculated with JLC2313 stackup. PCB manufactured by JLCPCB.
    Assembled board weighs less than 2g.
    What worked:
    - Microcontroller
    - Power regulators / switch
    What didn't work:
    - Solar charging
    - SPI flash
    Apparantly, the "optional" MPPC function on the solar charger IC was not so optional after all.
    I also messed up the symbol for the flash chip. The datasheet listed the BGA balls bottom-up, I assumed it was top-down.
View all 2 project logs
JessicaMila wrote 08/30/2024 at 03:15 point
It's inspiring to see such dedication to understanding and protecting wildlife. However, with the increasing risks to research sites, especially in remote areas, partnering with private security companies is crucial. Ensuring the safety of researchers and the integrity of their work through reliable security guard services is a smart move for sustainable conservation efforts.
Mary Robinson wrote 04/05/2024 at 03:34 point
 Utilizing MAST cells in wildlife research presents a promising avenue for understanding animal physiology and ecology. These specialized cells play a crucial role in immune responses, shedding light on wildlife health and environmental stressors. I also got a topic to write an essay about. Luckily I found this https://edubirdie.org/edubirdie-review-the-most-honest-and-reliable/ link where I read useful reviews about Edubirdie which is one of the best academic writing services I have experienced in recent times.
