#include "ibus.h"
// Edit here to customize
// How often to send data?
#define UPDATE_INTERVAL 10 // milliseconds
// 1. Analog channels. Data can be read with the Arduino's 10-bit ADC.
// This gives values from 0 to 1023.
// Specify below the analog pin numbers (as for analogRead) you would like to use.
// Every analog input is sent as a single channel.
#define NUM_ANALOG_INPUTS 8
byte analogPins[] = {A0, A1, A2, A3, A4, A5, A6, A7}; // element count MUST be == NUM_ANALOG_INPUTS
// 2. Digital channels. Data can be read from Arduino's digital pins.
// They could be either LOW or HIGH.
// Specify below the digital pin numbers (as for digitalRead) you would like to use.
// Every pin is sent as a single channel. LOW is encoded as 0, HIGH - as 1023
#define NUM_DIGITAL_INPUTS 12
byte digitalPins[] = {2,3,4,5,6, 7,8,9,10,11,12,13}; // element count MUST be == NUM_DIGITAL_INPUTS
// 3. Digital bit-mapped channels. Sending a single binary state as a 16-bit
// channel is pretty wasteful. Instead, we can encode one digital input
// in each of the 16 channel bits.
// Specify below the digital pins (as for digitalRead) you would like to send as
// bitmapped channel data. Data will be automatically organized in channels.
// The first 16 pins will go in one channel (the first pin goes into the LSB of the channel).
// The next 16 pins go in another channel and so on
// LOW pins are encoded as 0 bit, HIGH - as 1.
#define NUM_DIGITAL_BITMAPPED_INPUTS 0
byte digitalBitmappedPins[] = {}; // element count MUST be == NUM_DIGITAL_BITMAPPED_INPUTS
// Define the appropriate analog reference source. See
// https://www.arduino.cc/reference/en/language/functions/analog-io/analogreference/
#define ANALOG_REFERENCE DEFAULT
// Define the baud rate
#define BAUD_RATE 115200
#define NUM_CHANNELS ( (NUM_ANALOG_INPUTS) + (NUM_DIGITAL_INPUTS) + (15 + (NUM_DIGITAL_BITMAPPED_INPUTS))/16 )
IBus ibus(NUM_CHANNELS);
void setup()
analogReference(ANALOG_REFERENCE); // use the defined ADC reference voltage source
Serial.begin(BAUD_RATE); // setup serial
void loop()
int i, bm_ch = 0;
unsigned long time = millis();
ibus.begin();
// read analog pins - one per channel
for(i=0; i < NUM_ANALOG_INPUTS; i++)
ibus.write(analogRead(analogPins[i]));
// read digital pins - one per channel
for(i=0; i < NUM_DIGITAL_INPUTS; i++)
ibus.write(digitalRead(digitalPins[i]) == HIGH ? 1023 : 0);
// read digital bit-mapped pins - 16 pins go in one channel
for(i=0; i < NUM_DIGITAL_BITMAPPED_INPUTS; i++) {
int bit = i%16;
if(digitalRead(digitalBitmappedPins[i]) == HIGH)
bm_ch |= 1 << bit;
if(bit == 15 || i == NUM_DIGITAL_BITMAPPED_INPUTS-1) {
// data for one channel ready
ibus.write(bm_ch);
bm_ch = 0;
ibus.end();
time = millis() - time; // time elapsed in reading the inputs
if(time < UPDATE_INTERVAL)
// sleep till it is time for the next update
delay(UPDATE_INTERVAL - time);
