Here are some new FlexPCB received from OSHPark. This is another way to connect each module. It is easier to bend this than hardwires. But more expensive for sure. 120 in total.
![](https://cdn.hackaday.io/images/475441629330753682.jpg)
A project log for Modular PCB origami
The unique design makes its assembly independent of frames or jigs. Use hardwires to connect a pair of PCB and fold it into the shape.
