Hackaday.io Hackaday.io
Sign up Log in
EFEKTA PWS ZIGBEE
Wireless Mini Plant Watering Monitoring Sensor (capacitive soil moisture sensor), compatible with ZigBee networks (ZIGBEE2MQTT)
andrew-lamchenkoAndrew Lamchenko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.2k views
0 comments
16 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
  • 2021 Hackaday Prize
View Gallery
3.2k
0
16
6
Team (1)
  • andrew-lamchenkoAndrew Lamchenko
Join this project's team
  • EFEKTA PWS
  • Z2M Supported devices
completed project
MISC
cc2530 ZIGBEE Zigbee2mqtt Plant Watering 2021hackadayprize Soil moisture measurement sensor capacitive soil moisture
This project is submitted for
  • Hackaday.com Tip Line
  • Challenge 3: Reimagine Supportive Tech
This project was created on 08/04/2021 and last updated 4 years ago.
Description
Soil moisture measurement sensor project . Low power consumption, very small device. Built on the basis of SoC CC2530 (EBYTE). A simple and very cheap alternative to existing commercial solutions (MI FLORA). There are only 10 components, the assembly time is 10-15 minutes. A great solution for exploring mesh networks and IOT.
Files
2_2477.STL
Standard Tesselated Geometry - 4.34 MB - 08/11/2021 at 18:06
Download
2_2450.STL
Download
1.STL
Standard Tesselated Geometry - 7.63 MB - 08/11/2021 at 18:06
Download
3.STL
Standard Tesselated Geometry - 796.66 kB - 08/11/2021 at 18:06
Download
Project Logs
Collapse
  • Сase for a CR2477
    Andrew Lamchenko • 08/11/2021 at 18:04 • 0 comments
    A case for a CR2477 battery(950mA)has been added to the project.
View project log
Log In/Sign up to comment
Sign up with Github
OR
This project shows how to connect a SMT100 soil moisture sensor to a Dragino LoRa device and TheThingsNetwork
Project Owner Contributor
Soil moisture sensor with LoRa
maria-piechaMaria Piecha
Hackaday Prize 2019
Perky Sentry is a home automation project which detects outside vegetation fires.
Perky Sentry
guy-coleGuy Cole
I built a gesture sensor that works through solid objects—no exposed optics needed. Huge upgrade for my project!
I Built a Gesture Sensor That Works Through Object
realcorebbRealCorebb
These days most of the people do their job the whole day sitting and which causes back pain. This project is about coping up that pain.
Posture corrector
krishna-mohanKrishna Mohan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "EFEKTA PWS ZIGBEE", please tell us the reason.
Send message
Remove Member
