This project evolved from my previous Hoverboards for Assistive Devices project.
Note: This is a project summary, rather than a project history.
My Philosophy
I believe that you can create just about any mobile device if you have reliable drive components that are easy to use and configure. My goal has been to design custom mechanical, electronic and software components that can be combined with a commercial hoverboard to provide this capability.
- My firmware can be loaded into a specific model hoverboard to enable it to be remote controlled.
- My laser cut hardware components enable that hoverboard to be firmly attached to another assistive device.
- I provide a custom PCB and 3D Printed data-port to allow a standard network jumper cable to be plugged into the Hoverboard.
- I provide a custom PCB and software to allow an analog or digital joystick to be customized to the end-user.
- I provide several 3D printed Joystick housings as a starting point for further adaption.
Design information is grouped into the following categories:
- Hoverboard Modifications
- Mechanical
- Electrical
- Software
- Joystick Controls
- Mechanical
- Analog Joystick
- Digital Joystick
- Electrical
- Printed Circuit Board
- Software
- ESP32 Software
- Mechanical
Phil Malone
Jung Hoon Lee
