Today the PCBs arrived! Yay!
I soldered two of them which was kind of tricky since the components are really, really small.
The first one I soldered was a fail. I could see solder bridges under the ADP5360
chip. The second one (the one with the pin headers) turned out nicely and both I2C devices
showed up.
Except for a few missing capacitors that went flying somewhere and the one board with shorts (which I
kind of expected since it was a first for me) I am quite happy with the results up until now.
I have enough of the expensive components to solder 9 more which I will hopefully be able to do
this weekend.
Leonard Pollak
