Building visitor management system using the Waylay IO IoT platform and M5Stack modules.
For this tutorial, we have decided to use the M5Stack Ecosystem because it enables building such a system without prototyping specific tools, such as a soldering iron or prototyping cables. The brain of this project is the M5Core2, an IoT development kit based on the ESP32 microcontroller. This ecosystem allows you to connect the provided modules through a GROVE port to the M5Core2, allowing fast deployment of hardware.
The modules we’ve picked for this tutorial are M5Stack’s Finger Print Sensor Unit based on the FPC1020A capacitive fingerprint recognition chipset and the Mini RFID Reader/Writer Unit based on the MFRC522 chip.
BLACK - GND RED - 5V YELLOW - TXD2 WHITE - RXD2
