The back of the Z-Axis was casted in UPH concrete
At this point i decided to go full in and build up the overall machine from scratch. I designed it in CAD and continued with the Spindle cartridge, since it is the most difficult part.
Turning the cartridge
Grinding the cartridge
Turning the spindle shaft
Machining the draw bar
Finished draw bar (hardend to about 54 HRC - C45k)
Spindle watercooling mandrel
Finished spindle cartridge (after some iterations.. :) )
Assembled in the spindle holder
