The above picture shows the 8mm/10x focal lens assembly, which also can accomodate the 32mm plossl lens assembly also (attaches to the 38mm mounting coupler.)
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
