I designed this as an alternative to buying the actual eye piece if anyone would like to keep this aspect of the spectrometer 3D printable also. The only caveat is, you have to tap and die the set screw yourself (and the inside lens pocket,) and place an 8mm concave lens in the pocket and secure it in place (with the set screw.)
