This is the 3D printable version I designed of the 32mm Plossl focusing lens, you can use any 32mm lens that has a dia. of 29.78mm X 8mm thickness.
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
