This is the frame assembly from the previous drawings that illustrate the diffraction grating placement on top of the Schott glass filter at the detector. The DVD piece is cut @ 20 x 20mm and placed within the 1mm inlay of the frame with a dab of glue (DO NOT use crazy glue!)
