I had to add a 5mm wide spacer behind the 32mm lens, I found through some experimentation that the increased 5mm distance sharpened the image significantly by a factor of 4, so the old focal distance was 65.2mm from lens apex to mirror's center, now it is 70.2mm from lens apex to mirror's center.
