I have uploaded 1616 files from Jan 2016 - Oct 2016, which encompass all documentation relating to my first spectrometer build the DH4.0 v4 to the DAV5 V3 and all related absorption and emission spectra and excell files, PNG pics and data tables ect.,
The zip file is 83MB (quite large,) but a lot of information contained there in, even all my CAD files for the DAV5 V3 Raman spectrometer build. I still have about 9000 files left to go and trying to figure out a better platform for organizing the info like the NIST uses and others for data acquisition and downloading.
I feel this is important work, because it demonstrates the viability of citizen scientist and hobbyist's building instrumentation such as this and acquiring the same quality scientific results as the professionals do.
So this zip file is available only at my open source website at http://osf.io/x9gm6/files/
Just scroll down to were it says; "google drive files," and you will see it.
In process of enclosure re-design to accomodate the TCD1304DG detector ( the board dimensions are 100mm x 100mm) no way around it, both analog and digital circuitry are located on same board. I could not extend the PGM (serial port) because the TCD1304 does not behave properly and can be damaged by extending wires beyond 4".
