Finally, my M4 hardware kit from ThorLabs came in and I was able to fix the cuvette holder and also make the feet adjustable, using the M3 brass standoffs inlayed on the bottom and the M3 's screw right on in.
The kit item # is; HW-KIT1/M
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
