I fixed the R value for the trigger switch at D2, for the CCD signal data upload when the 3mm LED lights up, I put a 1.5 ohm resistor and it brought the current to around 0.8mA (each port is 100mA so everything should be fine.)
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
