*UPDATE* 3/4/2017 3:16:PM
I redid the SIM for the switch debouncer for S1, I included the LED indicator with its resistor to make sure the values stayed the same, do not mind the component at U1, I included it there because I needed a component to complete the circuit when it is closed and the components in the .LIB files are not cuttin' it. So it's just there to complete the circuit.
![](https://cdn.hackaday.io/images/4534941488658539737.png)
I added a simple single trigger switch debouncer at S1 on the main schematic for the CCD driver circuit, because this is the last stop where the frame data is waiting for upload.
The 220uf cap is to lock out S1 for 1 second after the pulse, since there will be another frame waiting in the wings.
