This is REV B of my Mega 2560 stepper Motor control circuit driver control board, I had to fix the switches as they were not working properly, now they do since I debounced them, I am posting a YouTube video showing it's operation
Below is the Arduino breadboard schematic showing the entire layout;
Next is the Fritzing schematic;
Here is the schematic for the LM350T voltage regulator;
Next is an Arduino barebones breadboard layout;
A 4 panel snapshot view;
Cool! Would you be willing to share the debounce function you wrote? I might need to debounce a breakbeam that I'm working on.
Hey Muriel, sure thing. 1st off though you really need the two 0.1uf caps and the 10k resistors at ground, because it eliminates any spikes from in-rush current at switch press (that's the hardware part,) now the software part;
//Variables will change
int ledState = HIGH; //current state of the output pin
int buttonState; //current reading from the input pin
int lastButtonState = LOW; //the previous reading from the input pin
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
void loop() {
//read the state of the switch into local variable
int reading = digitalRead(button_1);/*Name U defined as "button"*/
int reading = digitalRead(button_2);
// check to see if U pressed the button
//(i.e Input went from LOW to HIGH)
// if switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
//whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
ledState = !ledState;
Here is the entire code:
/*The circuit and code modified by me on 5/15/2017
David H Haffner Sr as part of my prototype triple
turret grating assembly, for my project 3D-Printable Raman Spectrometer
http://hackaday.io/project/18126-3d-printable-raman-spectrometer
The circuit as it stands now on a Mega 2560:
LCD RS pin to digital pin 8
LCD Enable pin to digital pin 9
LCD D4 pin to digital pin 7
LCD D5 pin to digital pin 6
LCD D6 pin to digital pin 5
LCD D7 pin to digital pin 4
LCD R/W pin to ground
LCD VSS pin to ground
LCD VCC pin to 5V
10K resistor:Trimmer POT
ends to +5V and ground
wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include
#include
#include
const int button_1 = 1;// variable for storing button's status(this is for my referene :))
const int button_2 = 0;// variable for storing button's status
const int ledPin = 13;
const int motorPin1 = 12;// IN1 on motor control board
const int motorPin2 = 11;// IN2
const int motorPin3 = 10;// IN3
const int motorPin4 = 9; // IN4
int val1 = 0;
int val2 = 0;
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(21, 20, 19, 18, 17, 16);
const int stepsPerRevolution = 200;
// Here set the stepper motor rotation step how much is a circle
int dim = stepsPerRevolution;
// Set the step motor number and pin
Stepper myStepper(stepsPerRevolution, 13, 12, 11, 10);
void setup() {
pinMode(3, INPUT_PULLUP);//Sets the buttons as input
pinMode(ledPin, OUTPUT);
pinMode(2, INPUT_PULLUP);
//set initial LED state
digitalWrite(ledPin, ledState);
attachInterrupt(1, counterclockwise, FALLING);
attachInterrupt(0, clockwise, FALLING);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Speed:");
lcd.setCursor(10, 0);
lcd.print("n/min");
lcd.setCursor(0, 1);
lcd.print("Direction:");
void loop() {
int redaing = digitalRead(button_2);
myStepper.step(dim);
void Direction();
// Read the sensor values:
int sensorReading = analogRead(A0);
// Map it to a range of 0-150:
int motorSpeed = map(sensorReading, 0, 1023, 0, 150);
// Set the motor speed:
if (motorSpeed > 0)
Serial.begin(115200);
val1 = digitalRead(1);
if (val1 == HIGH)
val2 = digitalRead(0);
if (val2 == HIGH)
myStepper.setSpeed(motorSpeed);
lcd.setCursor(6, 0);
lcd.print(float(float(motorSpeed) / float(200)));
void clockwise()
// clockwise rotation
lcd.setCursor(10, 1);
lcd.print(">>>>>>");
void counterclockwise()
// anti-clockwise
dim = -stepsPerRevolution;
lcd.print("<<<<<<");
