After exhaustively comparing the datasheets and performing software tests on different eval boards, it's become clear to me that these two parts are functionally identical down to the pinout, register map, and address map. The only difference I've been able to find is the onboard ROM.
Thankfully, since I'm not using the ROM, I can use these parts interchangeably which makes sourcing them significantly easier.
