I've implemented SNMP and the GPSDO logic. The software is currently using the frequency trimming support in the PTP hardware to under-clock the PPS and steer the edge alignment. Otherwise, the temperature compensation and PLL logic are working as expected. I still need to make a breakout board for the DXCO and I2C temperature sensor.
Temperature Compensation:
