Updates:
- GPS status via UBX protocol. (lower overhead compared to NEMA 1803)
- NTP client for fail-over on GPS/PPS loss.
- Improved stability of temperature compensation.
- Human-readable status via UDP port 23.
Human readable status examples:
$ echo -n 'ntp' | nc -uW1 -w1 #.#.#.# 23 gps epoch: 0xE7423F96.71E6AA43 ntp offset: 0xFFFFFFEE.00000000 ntp servers: pool.ntp.org address stratum leap reach next offset (ms) delay (ms) jitter (ms) drift (ppm) skew (ppm) weight - 38.229.60.9 2 0 77777 8 2.750 29.478 0.328 -0.142 6.376 0.1159 - 159.89.86.140 2 0 77777 5 7.713 23.209 0.390 0.317 8.137 0.0000 - 144.172.118.20 2 0 77777 10 0.260 9.997 0.190 0.267 4.714 0.1568 - 45.79.214.107 2 0 77777 7 2.613 7.500 0.404 1.649 8.263 0.0895 - 162.159.200.1 3 0 77777 4 0.576 10.040 0.249 0.512 4.612 0.1603 - 23.131.160.7 2 0 77777 10 5.772 29.849 0.178 0.402 3.595 0.2056 - 74.6.168.73 2 0 77777 7 3.304 35.071 0.310 0.232 6.270 0.1179 - 155.248.196.28 2 0 66767 4 0.970 25.825 0.194 -0.397 4.354 0.1540 clock stratum: 1 clock offset: 2.411 ms clock drift: 0.304 ppm leap indicator: 0
$ echo -n 'gpsdo' | nc -uW1 -w1 #.#.#.# 23 pps locked: yes current offset: -88 ns mean offset: -17.6 ns rms offset: 42.9 ns frequency skew: 0.0215 ppm frequency correction: -175.9287 ppm - pll trimming: 0.0839 ppm compensation: -176.0126 ppm - temperature: 37.834 C - bias: 37.230 C - coefficient: 0.4296 ppm/C - offset: -176.2722 ppm
Temperature Compensation Settling:
