CheerUp
A 3-D Printed Bot which can talk, cheer, dance and manage your day-to-day schedule.
Public Chat
Your personal assistant which can tell you your schedule, cheer you up by dancing and talk to you in his own Spongebob accent.
In childhood many of us have watched this show "SpongeBob Squarepants" , got inspired from it to create a virtual assistant to get our daily schedule and even cheer us up in this difficult time of work.
Instead of depending on phones for watching schedule we often get distracted , so using CheerUp we can avoid such distraction and work efficiently.
The Bot is Made from:
1. M5Stack Core 2 - It is a ESP32 based device which has peripheral devices like TOuch DIsplay Screen, Speaker, Microphone, LEDs, Accelerometer,SD Card Slot.
2. Servo Motors: These are used to actuate the arms of the bot.
3. 3D Printed Parts and Paints:  All the printed parts are the main attraction of this device , you can paint if you want.
4. SD Card: It is used to store the images and audio file of bot.
Features:
1. The device can be used even without constant supply of USB power as it has inbuilt battery.
2. You can modify the schedule as per your convinence
3. The code is easy to modify , Arduino IDE can be used with simple C++ code.
4. The device is moduler and portable and can be used anywhere.
5. You can configure the actions of the arm, currently there are 2 actions -Cheer and Dance.
Future Plans:
1. Integrating with Google Calendar.
2. Adding more cartoon characters.
3. Using touch to manage the faces of characters.
spongebob_leg v1.stl
Standard Tesselated Geometry - 54.57 kB - 08/23/2021 at 13:21
Download
spongebob_thigh v1.stl
Standard Tesselated Geometry - 43.64 kB - 08/23/2021 at 13:21
Download
spongebob_hand_1 v4.stl
Standard Tesselated Geometry - 49.89 kB - 08/23/2021 at 13:21
Download
spongebob_hand_1 v1.stl
Standard Tesselated Geometry - 48.52 kB - 08/23/2021 at 13:21
Download
spongebob_body v1.stl
Standard Tesselated Geometry - 4.57 kB - 08/23/2021 at 13:21
Download
View all 4 project logs
  • 1
    Print FIles
    Follow the Thingverse Link or Downliad Files from the Project Page for 3D Printing
  • 2
    Paint (Optional)
    Paint for better aesthetics
  • 3
    Merge
    Combine all motors and M5Stack to Printed Parts
View all 5 instructions
amr.koptan85 wrote 09/02/2021 at 08:51 point
this is lovely i like it alot, do you have a video for it in action ?
aniketdhole wrote 09/02/2021 at 09:17 point
Yes Added it in the Details of project
https://youtu.be/7nYg3oywTa0
benkster wrote 08/23/2021 at 20:49 point
Ok got it - github sorry :)
benkster wrote 08/23/2021 at 20:47 point
I like the look of this thingy - looking forward to see the code. Either it is not uploaded yet or I am blind and did not fined it ;)
