The new Stack-chan board (v0.1.1) is now compatible for M5Stack CORE2!
M5Stack CORE2 has touch screen. You can make touch interactions with Stack-chan.
Other than this the board improved many as listed below.
- Add paths between GPIO pins of COER2 to PWM servos
- you can choose Basic or CORE2 via jumper
- Add SMD diode for stability
- Add hole for mounting 25*2 pinheader
- Adjust screw hole
You can see the full difference in this pull request. And you can get PCB-manufacture-ready gerber files on my repository.
