You have to clone VinyGo git repository: git clone https://github.com/Mras2an/VinyGo.git
11.1) Hardware connection
11.2) Compile and program the code
See log 9) Flash and build ESP32
11.3) First boot
1 - Power on the VinyGo board, You see the LCD test menu.
2 - Click on it, and check all the tests (sensors, and commands). If it OK return to the menu
3 - Go to the calibration menu and make your calibration for 7, 10, and 12p vinyl.
4 - The system is ready, enjoy :-)
mras2an
How do you calibrate amplifier volume for the head ?
