Assembled unit, testing light sensor
A project log for clOCkTAL
Because binary coded decimal clocks are too easy to read.
danjovicdanjovic • 09/02/2021 at 02:10•0 Comments
Finished assembling the clock on a couple of 2x8cm perf-boards. Wiring is done using enamelled wire.
And here is the video of the clock working. I ran some tests with the buttons and the light sensor.
