While the first test was okay, this was more about ensuring that the position that the motors will stop at are going to be the appropriate location to push a product out. There was a problem with the one motor that will eventually need to be fixed where the circular disk that attaches to the motor is not solidified. A small dab of glue should correct though.
It was good to see it looking somewhat like a vending machine.
Matthew Potter
