Printing
Each of the 4 pieces took about 22 hours to print. I'd say the longest prints I have done up to date. Material is black PLA+, printed with a layer height of 0.2mm and 0.4mm nozzle.
Some parts have a rough look because I sanded them down a bit. This allowed for more sharp edges where I would paste the parts together, and helped remove some supports that just didn't want to separate.
As mentioned in an earlier log, I will join these parts together using some epoxy and threaded rods for increased stiffness.
Assembling the body
I cut the threaded rods to proper length, then filed the edges. With a small hand Dremel, made a groove so I can screw it in place with a flat screwdriver, and leave them totally inside the plastic.
Joined the pieces into two long halves first.
Then joined the halves to get a pretty sturdy body! Alignment was tricky, had to reposition the pieces removing the threaded rods and inserting them again. In the end, everything seemed quite square. Sanded the excess epoxy from the joints to make them smoother.
The grooves for using a flathead screwdriver ended up working a bit poorly. As the holes were tight with the rod, I ripped apart a couple of grooves using a bit too much force. Perhaps I should have made the channels that go through the body a little bigger in diameter.
Following, I will get this into better shape with sandpaper, plastic putty, primer and some black matte paint.
