SN74HC00N
SN74HC00N Product Information
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The SN74HC00N is a four independent 2-input NAND Gate IC. It performs the Boolean function Y = (A • B)\ or Y = A\ + B\ in positive logic.
• Outputs Can Drive up to 10 LSTTL Loads
• Low-power Consumption, 20µA Maximum ICC
• 8ns Typical Propagation Delay Time
https://www.apogeeweb.net/circuitry/sn74hc00n-texas-instruments-nand-gate-ic-datasheet-pinout-specifications.h
