Right now I be able to complete the Time / Date setting part of the watch, so overall features are
- Display Time in this format
Current Time: HH:MM:SS
- Display Date in this format, Note that XX is 01-99
Current Date: MON--01/01/20XX
- Left / Right Joystick button is for navigating through menus (now only two, Time and Date).
- To enter the setting mode, just navigate to Time menu or Date menu, and double press the center joystick button. Use Left / Right button to move the cursor (underscore as a cursor), Up / Down button for Increase / Decrease the value.
- Leap year capable, 29th FEB supported, month 13 proof.
- Left handed mode (still using in-code #define, Will make the proper setting menu later).
